Tamiya TT-01E "NEW" (stock)
About the Model
- Newly designed TT-01 type E chassis features brand new A Parts and D Parts.
- Damper Stay and Gear Case parts are made from fiberglass-reinforced resin for greater strength. These parts are now also separately molded to enable easier maintenance (regular TT-01 had damper stay and gear case molded as one piece).
- New front and rear uprights are also made from durable fiberglass-reinforced resin.
- Improved steering linkage design features TA05 steering posts for sharper steering response.
- New upper deck enhances chassis rigidity and mimics Tamiya’s high-level race-spec machines.
- Upper deck also features a convenient transponder mount to further encourage fans to go to their local track and experience R/C racing.
- Rear suspension arms installed in reverse position to create shorter wheel base for greater scale accuracy.
- 4WD shaft-driven bathtub chassis with coil spring damped, 4-wheel independent double wishbone suspension and sealed front and rear gearboxes.
- Unmistakable Porsche 911 body shape is accurately reproduced with lightweight polycarbonate.
- TEU-101BK ESC, Type 540 motor, and LEDs for headlights and tail lights are all included.
- 2-Channel R/C system, 7.2V battery pack & charger separately available.
- Compatible with a wide variety of Option Parts (sold separately).
- Flat Clear polycarbonate spray is being developed for an even more realistic finish
Re: Tamiya TT-01E "NEW" (stock)
'k ben momenteel bezig aan de Porsche-versie ervan.
Ik heb een vraagje: bij m'n kit werden wel velgen en slick-banden bijgeleverd maar geen inserts.
Welke monteer ik daar best in, of anders gesteld, welke inserts (TA-nummer?) bestel ik me best?
Ik heb er nu gewone TA05-banden op gemonteerd want zou liever die originele banden in één keer goed afwerken.
even aanvullen ...
heb nog flink wat opzoekwerk gedaan.
Blijkbaar hebben de bijgeleverde velgen (26mm breed en 2mm offset als ik me niet vergis) serienummer TAM 9335502.
Ik kan deze echter nergens vinden.
Wél vind ik deze: TAM 53914, dewelke ook 26mm breed zijn maar 0 offset hebben.
De bijgeleverde banden zouden deze zijn: 50454, maar eigenlijk weinig grip bieden (Tamiya raadt ze zelfs aan om te driften op harde ondergrond, las ik ergens). Beter zouden zijn 53293.
Kan iemand me zeggen welke velgen, bandjes en inserts algemeen gebruikt worden voor de TT01's?
Ludo,
bandjes voor de stockreeks in de tamiyacup zijn:
Standaard slicks (50454)
semi slicks (50810)
radial (50419)
of
med narrow slicks (51049)
med narrow radial (51023)
Dus geen med narrow slicks Type A (53293) bandjes
of geen med narrow slicks type B (53294) bandjes
Omdat de stockreeks een beginner reeks is en zo goedkoop wordt gehouden.
binnenbandjes zijn vrij (mousse of rubber) maar moeten van tamiya zijn.
tot zover het stock reglement.
semi slicks (50810)
radial (50419)
of
en welke bandjes zijn het best op tapijt en op asfalt? De standard slicks?
» tamiya cup voor offroad auto"s
» Tamiya TT-O1R (stock)
» Tamiya stock of mini?
» Tamiya TT-01 chassis (Stock)
» Tamiya Super Stock TZ motor
