Tamiya TT-01 chassis (Stock)
Bericht van ..l3art.. op ma jul 28, 2008 1:48 pm
The popular TT-01 lightweight bathtub frame chassis features a layout that provides low center-of-gravity and optimum weight distribution. Coil spring damped 4-wheel independent double wishbone suspension and differential-equipped front and rear gearboxes provide nimble handling performance. In order to achieve a greater scale realism, the wheelbase has been shortened by 6mm to 251mm. This car is also compatible with an extensive range of tune-up Option Parts, allowing almost endless customization possibilities.
Length: 440mm, Width: 187mm, Height: 125mm
Wheelbase: 251mm
Tire Width/Diameter: (Front&Rear) 27/67mm
Chassis: Bathtub type
Drivetrain: Shaft-driven full-time 4WD
Diff. Gear: Front/Rear 3-bevel diff.
Steering: 3-piece tie rod
Suspension: 4-wheel independent double wishbone
Damper: Front/Rear Friction damper
Gear Ratio: 8.35:1
Motor: Type RS-540 motor included
Speed Controller: ESC
TT-01 Body's
Bericht van ..l3art.. op ma jul 28, 2008 1:56 pm
