Tamiya TA06-R
Tamiya TA06-R
【 The Best of Both Worlds 】 The 4WD TA06 PRO chassis was created with input from the world championship-winning TRF team. Its layout positions the motor and battery pack along the centerline of the chassis and it is powered via a distinctive Dual-Drive System with belt-driven front and gear-driven rear wheels. The front suspension features a refined Inboard Front Suspension setup which mounts front dampers in a longitudinal position. The front and rear gearboxes are both equipped with newly-designed gear differential units to provide superb traction and acceleration. True to its name, it also comes with many PRO-spec parts such as TRF dampers, aluminum turnbuckles, and universal drive shafts. |
【 Included Option Parts 】 ●TRF Special Dampers (Hard Black Coating) ●TRF416 Low Friction Drive Belt (174mm) ●3×23mm Aluminum Turnbuckle Shafts ●3×32mm Aluminum Turnbuckle Shafts ●3×42mm Aluminum Turnbuckle Shafts ●Aluminum Ball Connectors (Blue) ●Hi-Torque Servo Saver (Black) ●Full Ball Bearings ●Universal Drive Shafts ●Low Friction Drive Belt |
Zou nog deze maand uitkomen!
